quote:
Q. What does AMSOIL have to replace GM Auto Trak II fluid?
A. There is little to no information available on the lubrication requirements of transfer cases calling for Auto Trak II. At this point, AMSOIL is not making a product recommendation for this application. AMSOIL is continuing research on this application in an effort to come out with a product recommendation. However our Drive train Fluids expert is looking into the performance demands of this fluid and to develop an AMSOIL product.
2002 GMC TRUCKS ENVOY 4.2L 6-cyl VIN Code S
FILTERS
Oil Filter......SDF64
Oil Vapor Filter......N/R
Air Filter......AF1135
Fuel Filter......GF344
Fuel Vapor Filter......N/R
PCV Valve......N/R
Trans......TF156, 4L60E D. Pan
Trans......TF113, 4L60E S. Pan
BOSCH SPARK PLUGS
XL
Wire......NR
Plug......NA
All submodels
Wire......NR
Plug......NA
BOSCH WIPER BLADES
Driver side......B40922
Passenger side......B40922
Rear window......B40916
CHASSIS LUBRICATION
Two-wheel drive
7-13 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
7-14 Fittings, 0 Plugs..........LB
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL-7500 Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 0°F......10W-30[1]
All Temps......5W-30[2]
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid
Differential, .....GLS[3]
75W-90
http://www.amsoil.com/products/svg.htm
Transfer Case,NV126,226.....SLF[4]
Special Lubricant-Fluid - Not Available Through Amsoil
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3 - Not Available Through Amsoil
Clutch Fluid.....HB
1. 10W-30 preferred in 1987,88 4.3L. 5W-30 in all others.
2. SAE 5W-30 is preferred.
3. GLS is a synthetic lubricant; GM part no. 12378261,
specification No. 9986115.
4. SLF is GM part no. 12378508 (U.S.), 10953626 (CAN).
CAPACITIES
Engine, with filter..........7.0 quarts[1]
Cooling System, Initial Fill..........14.0 quarts
Automatic Transmission, 4L60E Initial Fill..........5.0 quarts[2]
Automatic Transmission, Total Fill
4 speed 4L60E..........11.0 quarts
Differential, Front..........1.7 pints
Differential, Rear..........4.0 pints
Transfer Case,NV126, 226..........3.8 pints
1. Capacity shown includes filter. after refill check oil level
2. With the ENG automatic transmission operating temp, shift TRANS
through all gears. Let ENG slow idle in PARK for at
least 3 minutes. Check fluid level and add fluid as needed.
Do not overfill.
TORQUES
Oil Drain Plug.....19 ft-lbs
