Hello Group,
my 94 ES300 manual says to use Dexron III in the power steering reservior. I bought the car used about 20K/1.5 years ago and have never had to add any fluid to the reservior, however the fluid that is in there is definitely NOT Dexron III, probably regular old power steering fluid. I have never had a problem with my power steering in sub-zero temps or other conditions, but my steering rack is seeping a tiny bit. the fluid on the dipstick in the reservoir looks pretty clean, not much contamination.
1. Should I change it to Dexron III?
2. If so, what brand? anything in particular?
3. How do I change it?
4. does regular power steering fluid damage a car that is supposed to have Dexron III in it, or vice versa?
Thanks for the input!
Andy
Andy
