I recently bought a 1989 SAAB 9000CD Turbo for a great deal and I'm having a blast with it.
I changed the oil/Filter the third day I had it with Mobil 1 10W30 + 15W50. The trans fluid was crystal clear so I'm goin' down the list.
Next will be a GOOD cooling system flush and then a P/S fluid change.
Here is what SAAB reccommends:
Power steering fluid:
Saab Power Steering Fluid 1890, Texaco Power Steering Fluid 4634 (only available from Texaco in 25 litre containers), GM power steering fluid (Texaco TL 4634)
Haynes recommends "Saab or GM power steering fluid". I have also been told that any fluid from a GM dealer will do.
Can I just use Chevron Dexron III ATF or would that create a problem? I'll be honest, I don't even know the difference beetween P/S fluid and ATF
