the particular use is in a bmw 4.10 LSD rear end, that calls for castrol SAF-XLS 140 fluid. i don't know anything about royal purple, as i usually use mobil 1 product. thanks in advance.
Bror Jace---Your last paragraph is so true and factual. Thanks for a super post.quote:
Originally posted by Bror Jace:
My advice? Use the gear oil ... but know ahead of time where you can get a 4oz. bottle of the additive in case you need it. The different diff designs are a bit picky. What will satisfy some won't satisfy another.
--- Bror Jace [/qb]
What do you have in the rear diff now 75W90 or 75W140?quote:
Originally posted by ryan-e34:
just wanted to check back in. i was so disheartened at the noise that i thought the differential was making that I dumped the bottle of trans-x LSD stuff in without considering doing it afterward. the noise actually got WORSE on the 75w140/LSD add. it turns out that the tires on the drive axle were out of round, and solely the cause of the sound. i had put mobil 1 in a week earlier 75-90, and was beginning to hear a different sound when making low speed turns (which was probably it complaining for a tube of additive). the only noise from back there now is the sound of my exhaust leak .thanks everyone.
