The '91 Accord uses 2.5 quarts of Dexron II and is on a 2 yr/30K maintenance interval. Changing it is easy - you don't even need to jack the car up. Get the drain pan and newspapers together like you would with an oil change. Drive the car around for 10 minutes or so to get the tranny fluid hot, stick a 3/8 drive into the drain plug (located on the passenger side), loosen and away you go. Be careful and use gloves and a long sleeve shirt because the fluid will be HOT and will likely spurt out a bit. Put the plug back in securely and begin refilling a bit at a time, verifying fluid level. You will need a funnel with a long hose attached to fill it back up through the dipstick hole. When the dipstick reads full, start the car up and shift the selector into all positions from Park to 2nd, shift back into Park turn the engine off and recheck the fluid level.
Don't be alarmed by the sight of gray goop on the drain plug. It's magnetic and normally grabs stuff during routine operation. Just wipe it off before reinstalling. Compare the color of the old fluid to your new fluid - as long as it is still red, you are probably in good shape. If it is brown and smells burned, you will need to keep an eye on how the new fluid does. Black indicates trouble with the tranny. I wouldn't recommend any kind of flush on a tranny that age - you could wind up causing some trouble. Good luck!
[ May 16, 2004, 03:41 PM: Message edited by: darryld13 ]
