Changing brake fluid?
South Carolina
Another newbie question. This time related to brake fluid. I have never changed brake fluid and have 3 Toys (92 4x4/170K, 01 Hihglander/64K and 01 Rav4/35K). First, when should the brake fluid be changed? Second, what is the best method? bleeding? Thanks guys! This is one awesome site!
I use to change the brake fluid when I changed pads or shoes. But But after 8 years the original pads and shoes are still good so I changed the fluid anyway. Needless to say it was nasty
. From what I understand you should change the brake fluid every 2 years. This is especially true if you have abs brakes. They are sensitive to clean fluid. If you don't keep the fluid clean you can really mess up the abs system. And it costs a FORTUNE to fix. So it's cheaper to change the fluid every 2 years. My brother in law showed me how to do it by bleeding each wheel cylinder until clear fluid came out. It was a 2 person job. 1 in the car pressing on the pedal and 1 operating the bleeder screws. As long as you you don't let the master cylinder go dry while bleeding you can start on any wheel. But if the master cylinder goes dry or gets air in it then you have to start bleeding on the wheel furthest from the master cylinder and work to the closest wheel. My small Ford Contour used slightly more than a quart of brake fluid to do a complete change. Also be aware that if you haven't opened the bleeder screws on the wheel cylinders in a long time they may be rusted on and possibly break off when trying to open them. Perhaps you should soak them with a penetrating spray first. Also if you haven't changed the fluid in a long time bleeding them this way you can possibly mess up the seals in the master cylinder. Though I had no problem with mine after 8 years without bleeding.
Whimsey
What does your owner's manual say? Brake fluid doesn't last forever, and neither does rubber. For most cars, the brake fluid is replaced soon enough through rebuilding the calipers before the rubber parts go bad. I ran a 92 Grand Am with ABS 180K in 10 years and never changed the fluid as such, and never had any brake problems. I did rebuild the calipers and wheel cylinders, replacing most of the fluid. Also, get something in the way of a book, and follow the directions exactly on bleeding. I prefer real shop manuals to Chilton's, see www.factorymanuals.com. Changing brake fluid is mostly for hobbyists lacking useful things to do. Bleeding may or may not remove the the old fluid from the bottom of the bore where the damage occurs. It also does nothing for the critical area between the O-rings and the boots in a caliper.
Do you change brake fluid based on color? My 2002 Camaro is going on 3 years old and it still looks bran new. Should I change it?
Brake fluid is hygroscopic. It should be replaced every two years. I a mild climate without high humidity and no low temps, you might get away with 3 years. If water builds up in the brake system you will get corrosion, you will damage your ABS controller, and most of all, in an emergency situation, your brake fluid (actually, the water in it) will start boiling and you will not have the braking power you need.
I've always replaced brake fluid at a maximum of 3 years and have never had a single problem with calipers, wheel cylinders, master cylinders or lines. This includes a 19 year old VW with over 150k miles and a 13 year old Ford pickup with over 200k miles. My feeling, anyway, is that the water causes corrosion which affects the seals. From my experience with this, master cylinders, lines, wheel cylinders and calipers should be "life of the car" components as long as the fluid is kept clean. My VW maintenance schedule shows brake fluid changes at 2 years. They don't bother even talking about coolant and gearbox oil, which obviously need to be changed periodically. So if they put it in the book it means something IMO.
It's a 20 minute job max with this: http://www.motiveproducts.com
I have no connection with Motive other than being a very happy customer. This tool is definitely worth the money (doesn't cost much) and makes it a quick one person job with easy good results. You can build one yourself out of a plant sprayer too.
Maybe that is all the longer the Eurospec stuff is good for. I never heard of any problems due to not changing brake fluid in a For or GM product.
quote:
I've had Ford and GM products with old fluid and corroded wheel and master cylinders, so please don't say that again. Because it wouldn't be true.
Every 2 years is a good goal. Not more than 3. Brake fluid is hydroscopic. If you go off roading and drive through creeks, you may have to change b. fluid more often. Agin due to water contamination. I like Haynes manual better than the Chilton. The factory service manual is always better, but much more expensive. Look for a one man bleeder system such as Vacula or Phoenix. Go on the Toyota lists for more specific details.
If your taking the car to the track, road course, or racing on the weekends...
Its generally recommended to change at least once during the season, with a minimum of once per year. (Usually two times on light duty racing, and any where from every other race to every race if its heavy).
There are a variety of applications which make bleeding the brakes much easier then with default equipment, like speedbleeders or power bleeders.
Bleeding your brakes also firms up your brake pedal, depending on the type of braking feel you want.
With the right setup, it takes less time to bleed your brakes then it does to get the car on jacks and the wheels off...
Labman, I've been following your advice on brake fluid for some time now. Some of what you say makes sense, but not all of it. Your advice holds water for people that drive 15-20K each year, and renew their brakes every 2-3 years. But for people such as myself that have multiple cars and drive few miles, we need to follow a more regimented maintenance schedule than what the owner's manual recommends (which is sometimes nothing). The past couple of years I've put no more than 3K per year on any of my vehicles. I need to protect these braking systems from corrosion and I don't want to wait until the pads are worn or the caliper siezes.
I do like your advice of buttering healthy caliper bore and piston surfaces with silicone grease to prevent corrosion at the critical seal surface. I'll try it on my next brake job. I'd like somebody else to verify this practise.
My '85 VW uses standard DOT3, and my '97 VW uses DOT4. Same stuff you can go to Napa and buy, and same as I put in our Dodge, Ford and MG.
And it does improve pedal feel, believe it or not. I would never have believed it if I hadn't felt it the first time. I don't know how, because the water is just as incompressible as the glycol, but it does.
[ April 30, 2004, 11:23 AM: Message edited by: gatesj ]
You get a small amount of air in the hydraulic fluid over time. That's the main reason you feel a difference after you bleed your brakes.
Even a fraction of 1% air makes a big difference in the bulk modulus (stiffness) of hydraulic or brake fluid.
See fig 2.2 on page 5. It's about hydraulic fluid, but the results are about the same for brake fluid.
http://www.aero.polimi.it/~l050263/bacheca/Dispense_EN/02-FluiMech.pdf
The whole paper is interesting.
Flush your brake fluid once every 2 years and you are unlikely to ever need to rebuild a master cylinder, wheel cylinder or caliper. Leave the fluid untouched and you can count on eventual corrosion. For some reason almost all european brands spec every 24 month fluid changes while GM and Ford say nothing on the subject. This is not due to any weakness of the euro products, but rather is because they are telling it like it is.
Anyone who says they "haven't seen a problem" from old brake fluid simply has not looked closely enough. Tear down and inspect the components of a ten year old brake system with it's original fluid and you will find corrosion.
The easiest way I've found to flush multiple cars at a reasonable cost is with the Motive Products flush system. It costs around $50 configured for a single type of vehicle, more if you get multiple adapters. $100 sets you up for 99% of the cars on the road.
Motive Products' Website
I used to use Castrol LMA fluid as an everyday high quality brake fluid. LMA is still around and is still good stuff, but it is not as widely stocked as it used to be.
Lately I've switched to Valvoline Synpower brake fluid as it is a fluid with much better than generic DOT3 specs, is readily available and is reasonably priced. Our local AutoZone carries it at about $2 more per quart than the generic DOT 3 stuff. Figure on one quart per vehicle for a complete system flush. You want to run fluid through until it comes out as clean as the new stuff going in. Used brake fluid gets darker as it absorbs moisture and contaminants.
John
quote:
Originally posted by jthorner:
Flush your brake fluid once every 2 years and you are unlikely to ever need to rebuild a master cylinder, wheel cylinder or caliper. snip...
John
Bull. One of the most vulnerable areas is the caliper piston between the O-ring and the boot. Even if you change the fluid daily, the piston still has the same old fluid or lubricant in that area. Caliper pistons retract very little in normal use. As the pads wear down, more and more of the piston is beyond the O-ring and fluid in the caliper, hardly retracting at all to release the pressure of the pads on the disc.
I have disassembled hundreds of calipers. All the ones that had a corroded piston, the corrosion was on the outside of the piston beyond where it has contact with the fluid in the caliper.
The rubber boot is one of the most critical components of the caliper. It alone protects the piston beyond the O-ring from the air and moisture. Anybody that doesn't think it is important to replace them occasionally is out of touch with reality.
Not replacing the brake fluid as mandated by the manufacturer represents gross negligence and goes against common sense. If someone has corroded caliper pistons or other failing components, then this is certainly due to a lack of preventive maintenance. Parts don't corrode over night and out of the blue. There is no room for error with brakes on a car, but so many people just drive their cars until something falls off.
quote:
You could say the same about a manufacturer that doesn't recommend replacing brake fluid every few years.
I think the majority of people agree that brake fluid must be changed every 3 years at a minimum as part of responsible maintenance schedule.
Person(s) who say otherwise are in the majority and aren't planning on paying for your neglect (repairs, brake failure) when you follow their advice.
I also suggest those who don't want to do a full bleed to refresh the fluid in the resovoir every year using a turkey baster. Entropy and use will mix the new clean/dry fluid with the old fluid and is much better than doing nothing. Many cars also have a strainer in the resovoir, this catches solids and can be washed, DRIED, and reinstalled at the same time.
Let me tell you what happens when you don't change your brake fluid. I had a friend with a vehicle that you had to stand on the brake pedal with both feet to get it to stop when cold. We bled out the old brake fluid, it was black, murky, and had plenty of solids in it. After the change the brakes worked perfectly. He thought he was going to have to pay for costly brake repairs, we spent about $5 and he was driving a much safer car.
[ May 01, 2004, 09:47 AM: Message edited by: S2000driver ]
I'm a big proponent of regularly flushing brake fluid as proper preventive maintenance.
But I have to agree with labman that this maintenance will not guarantee that calipers will remain corrosion-free. There just isn't enough turbulence in the thin gap between the piston and bore to properly refresh fluid from the critical seal area. Plus this critical area is away from the fluid flow path between brake hose and bleeder screw in the caliper bore. That is why I'm turned on to the idea of buttering these critical areas with silicone to prevent corrosion and extend the useful life of the calipers.
