JB, you are a man after my own heart. Before doing the first ever gear oil change and dumping the Factory Fill in my 5-year-old truck, I did a careful study of all the gear lubes out there. My gearbox needed a GL-4 and my diff's needed GL-5. I eventually settled on Redline MT-90 for gearbox and Schaeffer Supreme 267 Gear for my differentials. I nixed Mobil 1 gear oil because in performance terms, it did not come anywhere near Redline and Schaeffer. I did not consider price; if it measured up performance-wise, I would be willing to pay many times the price of regular gear oil.quote:
Originally posted by JohnBrowning:
Here in the USA you can buy Redline for about the same price as M1 Gear Lube.
With M1 you pay about the same as you would for Redline but you get one product. THeir one product is a good gear lube and works well in diff.'s. THe difference is that M1 gear lube does not come close to Redline in terms of shift feel or performance in manual transmissions. M1 does not make a product like Redlines Shock Proof gear lube.
So it is not that M1 gear lube is a bad product it is that it is too comprimised for anything other then stock differientials(sp). M1 would have to formulate more specific products to compete with Redline.
For what it is worth I have never had conventional gear lube fail to provide all the performance I needed.
My experience with conventional (dinosaur) gear oil is the same as yours. the Dino Factory Fill in my truck worked hard for 5 years, and still looked good when I dumped it out to make room for the Redline and Schaeffer's. I will be more than satisfied if I get the same length of service from the fancy synthetic and syn-blend gear oils as I did with good old dinosaur gear oil.
