This weekend I desided to flush my trans. and change filter. It's a 97 GMC with 80000 miles on factory filter. I disconnected the radiator line and pumped out fluid until flow began to slow. then I dropped pan and changed filter. After this, I added back seven quarts and flushed till I got BRIGHT red fluid out. I then added back three quarts and ran through all gears. When i went to check level it was almost 3/4" over full mark! I got really scared and decided to empty pan again. Luck had it I welded a plug in while i had it off. I let the pan drain and added five quarts back. This is what my Hanes book said was required for a pan drop. Now my level is still over full mark even after draining an additional quart. Please help!!!! Also, how in the world are you supposed to get a good reading off the dipstick when it does 60000 bends to get to the pan? I really suck at this.
