Hi;
I recently had the ATF and filter changed in my GM 4T60-E Automatic transmission in my '92 Oldsmobile (at about 33K miles on the old ATF. They said everything looked/ran o.k.)
I have a question about what the 'proper' color characteristics of the new fluid should be, since the new fluid seems darker/murkier than I expected when viewed in a 4 ounce glass jar.
Since the change had only replaced about half the ATF (previously Dexron IIE, now Dexron III), I thought I would try to do a more complete change by suctioning out the fluid through the dipstick and adding new fluid a couple of times.
After doing this I ran the car a hundred miles or so and extracted a few ounces to examine. Even though the fluid doesn't look bad at all on the dipstick, sitting in a 4 ounce baby food jar (about 2.25 inches diameter) the fluid looks noticably darker than new unused ATF.
The unused ATF is clear, cherry red whereas the new fluid has an almost brownish somewhat cloudy appearance.
As I said, looking at this current fluid in a thin layer on the dispstick, or in a few drops on a paper towel doesn't look bad at all. It's only in 'depth' that it seems significantly different than unused fluid.
Is it normal for the new 'used' fluid to be darker than unused fluid after a change on an an 'older' transmission?
Hoping this isn't a sign that the transmission is self desctructing, I was wondering if this could just be residual 'gunk' that was now being dissolved or suspended by the new ATF.
Thanks;
-Greg Bohn
Thanks;
-Greg Bohn
