With the first setup, it lowered intake temps, in stop and go, to ambient. I don't remember the exact figures, but say on a 80F day, the intake temp was 80, rather than 140.
Fuel economy? Did nothing, either way.
Throttle response and power? Much better in stop and go. Little difference on the highway.
Keep in mind that most "cold air" systems are not. If you hang a cone filter out in the heat of the engine bay, you are, likely as not, reducing power, except at highway speeds, when the air stays cool under the hood. My "Poor Mans Cold Air System" or PMCASS, actually delivers cold air to the engine.
Opening up the bottom of the airbox and "porting" the top, allows more airflow through the system.
If you want to monitor your Intake temps, and don't have scanning software, just get a digital indoor/outdoor thermometer at walmart in the automotive section. Open up the intake system, slip the sensor inside, and route the wire to avoid hot spots and belts.
[ May 17, 2005, 11:36 AM: Message edited by: VaderSS ]
