I'm doing the same and agree 100%.quote:
Originally posted by mtgrs737:
Mobil One Racing 2T in everything at 32 to 1 it's super clean and the best 2 stroke oil on the planet.
Most people use this oil at 100:1 0r 80:1 so I figure I'm safe going 64:1. Plus it's easier to measure with this dose. If I was using any other oil I would mix it stronger.quote:
Soupy, 2oz. per gal is 64 to 1. A bit lean in my book, but it's your equipment. I can't figure out why so many people want to use as little oil in their two-cycle engines as possible. The same people wouldn't only fill their car engine half full. I don't get it.
Autozone in Oklahoma do not carry this oil. Anyone what other retailers are stocking it?quote:
Originally posted by FowVay:
I also exclusively use the Mobil Racing 2T oil available from AutoZone.
Oils labeled ISO-L-EGD seem to be top shelf products.
I think the people that run higher ratios are the same people that don't believe in changing their oil every 3months or 3,000 miles. We all know that motor oil lasts longer than 3,000 miles. Why is it so hard to believe that a good 2 cycle oil can be run at higher ratios?quote:
It's not about quality of the oil, It's about quanity of the oil that can be the destruction of a two-cycle engine. I will admit that oil quality is important, however when you consider that in a two-cycle engine the oil needed to keep those finely fitted machined parts from making actual contact is just passing through, I for one want to make sure that there is enough to do the job right. After all it's only oil, most folks don't use enough two-cycle mix to worry about the oil useage. Also consider this, the more oil the more additives, things like detergents, anti-wear agents, and dispersants. I run everything at 32 to 1 and I don't have problems with carbon build up, smoking, or oil driping out of the muffler. I don't get the high ratio thing at all, WHY would you risk running less oil?quote:
I own a lawn care service so it's different for me. Any old two cycle oil would be fine at the correct ratio for a homeowner. My trimmers and blowers are used on 10-15 properties a day and see no problems running Amsoil at the 64:1 ratio. I'm not brave enough to try the 100:1 because Amsoil states to use 80:1 in severe use. I decided to go with the 64:1 because of the added oil and the ease of measuring the mixture.quote:
Here is my $.02 on my reasons for using the lean mix ratio.quote:
There seems to be two schools of thought on two-cycle oil, the use what the engine manufacturer recomends and the use what the oil manufacturer recomends crowds. I guess I'm in the first group. I have read many posts from the Opti-2 Amsoil folks and from what I've read their choice of oil and ratio seems to be working for them. However, I have taken the advice of lawn-care professionals and small engine service shops in my area and use the full quanity of lubricant recomended by the engine manufacturer. Actualy I have been advised that the 50 to 1 engines should be mixed slightly heavier to avoid reduced longevity. I still have some Amsoil Saber on the shelf that I use as an engine prelube, I figure it is loaded up with anti-scuff additives and should work well till the mix oil is flowing through.
I agree that it makes no technical sense. But I have to believe that Amsoil has tested their product on more than 1 type of 2 stroke engine and has found it to perform well in most "most" applications. Their web site has a recomendation table as which 2 stroke oil to use for which application.quote:
Originally posted by TooSlick:
The idea that every two cycle oil works best at the same mix ratio, makes no technical sense at all. Certainly the quality of the basestock and additive chemistry and the amount of stoddard solvent in the mixture all come into play when determining optimum mix ratios for a particular formulation.
TS
