2003 Chevy Impala, 3.8L/4T65E, Unknown mileage as the cluster display is dead, Car/Owner is from out of state (Northeast) so the car is RUSTY & I'm not used to dealing with that. Car is very ROUGH POS.
*Complaint......High Idle, Hard start, & Poor fuel economy.
NO trouble codes present.
Scan data revealed high TPS voltage at closed throttle (1.63vdc), Thought to myself--Bad TPS! 'til I unplugged it & the Voltage went up to around 2.55vdc!
*Jumping Low Reference to the TPS signal brought it back down to 1.63vdc.
*Jumping a Ground right off the battery to the TPS signal resulted in the same 1.63vdc.
*Jumping the 5vdc Reference to TPS signal resulted in 4.99vdc in scan data (Normal).
Decided to look through the rest of the scan data PID's before I "Disassemble Johnny Five" & backprobe all powers & grounds at the PCM.
*Everything looked normal (KOEO/Engine at ambient temp) EXCEPT the O2 sensor voltages were hanging out at around 80Mv where they should be right around a half volt (.447Mv) or so with a cold O2.
*Disconnected the front O2 as it was easy to access & nothing changed per the B1S1 PID.
*Using my incandescent test light hooked to 12vdc.....Voltage would jump 10.23vdc. This IS high voltage for this circuit....But the test light WILL NOT allow enough amperage pass to do harm!
*With my test light hooked to ground.....No change it voltage.
This is a situation where Operational Theory is your best friend!!!
*The TPS signal has a Grounded resistor inside the PCM to assist in providing a clean/noise free low voltage Sensor Input. Therefore the Voltage on the circuit should drop to 0vdc when the TPS is unplugged.
*The O2 signals (GM) have Resistors that are Powered with a power supply within the PCM @ .447Mv, Same theory as the TPS but uses a bias voltage that is exact CENTER of the voltage range for the O2.
At this point I already culled the PCM as faulty.....However I did my due diligence & installed the old 3.8L/4L60E that was in my Camaro before I V8 swapped it (They are "keyed" the same & the SAME PCM besides the calibration)
*TPS voltage fell to 0vdc
*O2 sensor voltages rose to .447Mv.
I concede that I lucked out by having a test PCM in my cabinet to prove out my diagnoses, However......The rest of the Input sensors worked flawlessly & The 5 Volt power supply was operational which tells me Powers & Ground to the PCM are sound.
First photo.....TPS grounded resistor. Arrow.
Second photo.....Bias line on the O2 signal circuits. Arrows. It doesn't denote what voltage but that's how I read them. Some diagrams will denote a 5vdc resisted bias!
