Originally Posted by SubieRubyRoo
Yep they are very dependable cars. Maybe not the flashiest, and you need to change fluid on the 6F35 frequently, but they're definitely decent transportation. I have a 2011 SE with 123k, 104k of it mine. Only thing that's been replaced were the rear pads and rotors once at 46k, other than that just normal maintenance- oil changes about every 13k, trans fluid every 50k with Amsoil ATL, and antifreeze and thermostat (preventative only) at 100k. Great car, if slightly boring with the 2.5.
Any Gen 1.5 Fusion Sport will not have the 6F35 - It will have the Aisin TF80 transmission, and thus will not be subject to the same requirements of the 6F35. Seems to be a more forgiving trans. It also uses different fluid (T-IV fluid) than the 6F35 trans, which requires Mercon LV.
That said, the Gen 1.5 Fusions (2010-2012) are overall extremely dependable cars, and the Sports are pretty fun to drive so you really can't go wrong with one. As you can see, the 2010 in my sig is way up there in terms of mileage.
