Hey all:
I have a 9-10 year old electric dryer, Admiral model: AED4475TQ1. The dryer has not been completely drying clothes in one cycle recently and I had attributed it to a clogged vent or internal exhaust ducting in the machine. Last week I took the back off and cleaned all the duct work and didn't really find a significant amount of lint/hair but did clean it up. Since then there has been no improvement.
I read around online and found that the moisture sensor will sometimes get dirty and not read the true dampness of the load and thus stop calling for the dryer to run and you're left with wet clothes. After a load (2 cycles on the 'dryest' setting autosense had) I unloaded it and looked around the drum only to find that there is no sensor that I can see, I even looked on the front wall of the dryer and cannot find anything.
Anyone know where else the sensor might be on this unit?
And before someone says "just don't use autosense" the machine ONLY has a max of a 30 minute cycle on timed dry and that has proven to be completely ineffective.
