Need a proper Technical name for the three (3) metal (..or wood) support posts on the underside of a flat roof.
Description:
Flat roof is an extension of an existing sloped tile roof and was built as a patio/pool area roof.
A concrete beam runs horizontally on the extreme outer edge of the flat roof and was designed to be supported by 3 underside posts. A concrete raised surface is on the patio floor and originally there were metal posts approximately 7 to 8ft long mounted vertically between a square concrete post and the concrete beam on the underside of the deck.
What is the proper name for these 3 posts, originally they were square shaped hollow steel/iron ?
Bonus points if anyone can provide a link to a supplier that sells these with mounting hardware.
Description:
