Originally Posted by GOPHER FREAK
Motor is a 2009. As far as the impeller, in my younger days I worked at a Marine dealership as a mechanic. Replacing perfectly good impellers was the number one money maker in the service department. This idea you change them every year is nuts. If you don't run them dry, they last forever. Not a ton of risk running them either, the motor has telltale and also an overheat alarm. That said, I'm aware I might have to come in on the kicker some day. But I just don't replace good parts.
I was told every three years is a good mtce plan? It's far too late now anyways, but with the amount of hrs my engine likely has towing my son around tubing, kneeboarding and waterskiing, I am sure it/they were likely due anyways?
The last 2 years, with far less hrs put on the boat, I think I will hold off another year or 2 if I am due this year?
