98 civic with 150k km on it.
There is a leak due to rust coming from the stamped seams of the fuel tank.
Replacing tank may result in gas lines also being damaged in the process. Mechanic mentioned that to me.
He also said I can try tackling it via sealing that part with standard JB weld.
I have looked at the different types of epoxy and wondering if there is any reason I shouldn't try using steelstik instead of the standard 2 part paste mix?
