How much White smoke coming out the exhaust for a 2 Stroke is normal? The Backback blower I have seems to be blowing alot of white smoke out and i can't seem to adjust the carb right to lessen it. I adjusted the carb on both the H&L screws to 1.5 turns out to fix a hesitation i had and now no matter what adjustments I make on the carb richer or leaner it just blows out alot of white smokeas I give it some throttle. What am i doing wrong or could it be something else other the the carb adjustments causeing the smoke? Most people from another thread said that 1.5 turns out on the carb screws should be just about right and just fine tune from there, but i can't seem to get rid of the white smoke. thanks for the help
