Originally Posted by dnewton3
I recommend a sample around 10k miles, then again at 20k miles, then again at 30k miles, if the extensions seem warranted. Since you have a Fumoto, this will be easy to achieve.
Pb isn't high enough to be worthy of panic, but it's just cautionary and a reason to pay closer attention. If the wear increases, you've got your answer. If it drops down again, it likely was a particle streak.
Patience and diligence are the keys to success here.
I just spent some time reading your article on "what is normal"—great info there!
One thing is apparent—I really need to be more diligent in maintaining a consistent sample interval in order for the data to be more useful. Sometimes that's a bit hard to do as this truck (and me in turn) run long hours when out on the road. Combine that with the lack of "blue boxes" at truck stops to send the sample off (it's hard to drive up to the post office in a 70 foot long vehicle). For example, the last sample was pulled on 7/31. It probably rode around on my dash for another two weeks before I saw a mail box at a truck stop in Amarillo and remembered to actually drop it in the mail. I got the report back on 8/31 and in that time, 11,763 miles passed. That's a lot of miles going by if something needed attention.
I am a bit relieved though, after looking through other samples and seeing that those numbers really aren't too terrible.
