Egg Casserole
by chiefsfan1
2 minutes 54 seconds ago
What oil would you recommend for my driving?
by Dylan1303
10 minutes 53 seconds ago
Racing oil not recommanded for street use ??
by ST2008
Today at 05:10 PM
Vlad is the oil guy?
by CharlieBauer
Today at 04:56 PM
2015 Tacoma 4.0 V6, 9.8K mi. Amsoil Signature 5W30
by btanchors
Today at 04:54 PM
Sounds of Black Holes Merging
by MolaKule
Today at 04:53 PM
BEST BROWSER?
by Eddie
Today at 04:46 PM
Are Cooper CS5 LRR?
by Stewart Fan
Today at 03:14 PM
Camry battery tested bad.
by chiefsfan1
Today at 03:08 PM
Electricly conductive grease for Samsung Galaxy???
by Drew99GT
Today at 01:40 PM
Right Oil and OCI for my Application?
by lancerplayer
Today at 01:06 PM
AZ card 20% off, AAP card 13% off
by gojoneeded
Today at 12:44 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
88 registered (86cutlass307, andrewlg, AEHaas, 09_GXP, ag_ghost, AIRJAC3, 8 invisible), 1533 Guests and 9 Spiders online.
58973 Members
66 Forums
253822 Topics
#484227 - 08/31/04 06:14 AM Fuel Ratio for Mobil MXT2 on Husky chainsaw
vrsc Offline
Loc: Central, Fl
Hello, I am a new member and have been reading this informative forum. I did a search and could not find a true answer for this question. What Fuel Ratio do you use for your Husky Chainsaws when using Mobil Synthetic MXT2. I have heard ratios form 32:1, 40:1, 50:1 and 100:1.
Also, has anyone every used the craftsman synthetic oil 3.2 oz bottles in these saws. If so what is your opinion of its quality and do you still use the 50:1 ratio.
Thank you in advance for you advice:D
#484228 - 08/31/04 06:16 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
Brett Miller Offline
Loc: Arizona
40:1 will work well. If you are really running it hard 32:1 would be a good idea.
#484229 - 08/31/04 09:53 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
Blue99 Offline
Loc: Wisconsin
Many of the Craftsman chainsaws are supplied by Poulan. Poulans tend to run at a 40:1 mix ratio, 3.2 oz. per gal. There's a good chance that this Craftman oil is also supplied thru Poulan or the Poulan 2 stroke oil blender source.
#484230 - 09/03/04 05:44 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
Cujet Offline
Loc: Jupiter, Florida
I have a Husky 345 chainsaw and My oil ratio of choice is 32 to 1. As a general rule, 32/1 or 4 oz per gallon is sufficient lubrication for nearly all applications and conditions. The only exception would be outboard engines, where the 50/1 ratio is sufficient due to low stress and moderate temperatures.
Chris
#484231 - 09/07/04 01:37 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
hk33ka1 Offline
Loc: Ontario
I have been running Amsoil Interceptor at 32:1 with no problems. Runs smooth with minimal smoke for a 32:1 mix. Husky 357XP and 371XP saws BTW. What I like about 32:1 the most? I use one gas can for all my 2 stroke needs. Mind you I have gone to 4 stroke Hondas for most of my small engine stuff.
#484232 - 09/10/04 09:48 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
harrydog Offline
Loc: Ohio
I finally found a place that sells MX2T and picked up a bottle. There is no mention of mix ratios on the label. Is this oil capable of 50-1 or should I mix it richer? Most people seem to mention 40-1 or more. I want to do the best for my equipment, which is all 50-1.
Thanks.
#484233 - 09/09/04 10:13 PM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
Loc: Arizona
50:1 will work fine, however, 40:1 will give better protection. You won't see much smoke at either ratio.
#484234 - 09/10/04 12:58 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
harrydog Offline
Loc: Ohio
If my calculations are right, for 1 gallon of gas I should mix 2.6 oz of oil for a 50:1 ratio and 3.2 oz for a 40:1 ratio.
It's not likely that I can get it exact, but it sounds like if I just mix 3 oz to a gallon I should be fine. Right?
The MX2T is meant for motorcycles, so I wonder if it's formulated to work at just about any ratio or if there is an optimum ratio. I'm talking the oil itself, not the equipment.
I know I'm making too much of an issue out of this. [No no] Bad me.
#484235 - 09/10/04 02:33 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
darrenc Offline
Loc: West Coast
Yes, 3 oz. per gallon would be more than fine (that's about 43:1). **** , I run the Amsoil stuff in my Husky at 80:1, and have never had a problem.
#484236 - 09/10/04 02:58 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
MolaKule Offline
Loc: Iowegia - USA
Three to four ounces/gallon is fine.
I prefer a slightly lower ratio, say 32:1, so I use 4oz./gallon.
#484237 - 09/10/04 03:02 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
darrenc Offline
Loc: West Coast
Mola,
Do you still have problems with your Poulan's seizing at leaner ratios?
#484238 - 09/11/04 06:08 AM Re: Fuel Ratio for Mobil MXT2 on Husky chainsaw
Hirev Offline
Loc: Oregon
I run 32:1 oil ratio in chainsaws and dirt bikes.
