Arbee, the reason I use a 40:1 mix is that i have some equipment that calls for that ratio. I did not like mixing two different ratios, so I tried the MX2T at 40:1. With a carburetor adjusted correctly I did not get any smoke at that ratio. I figured a little more oil wouldn't hurt so I stayed with 40:1 even with my equipment that calls for 50:1. I have been using the MX2T for about a year now because it is much cheaper than the Echo Power Blend and Husqvarna XP oils that are readily available around here. It is about half as expensive and I think that it is a better oil. You stated that you have a Red Max EB7001 (I have only seen the EB7000 model)blower. They are about $500 around here. With proper maintinence, It will last you the rest of your life unless you use it commercially. If Red Max calls for a 50:1 ratio run that ratio, but You won't hurt it running it at 40:1 with the MX2T.
Getting back on the topic of Opti-2. There is no way I would run anything at 100:1 ratio that was designed to run at 50:1. What is the purpose of running half the amount oil in the gas?
