My current snowthrower has a Briggs & Stratton 8 HP 4-cycle engine (flathead, not OHV). The engine does not have a lot of hours on it, and I have have always used Mobil 1 5W-30 oil in the crankcase with good starting and low oil consumption. This Fall when I changed the oil, I put in M1 0W-40 - thinking it might be an ideal oil for the application - good cold flow and higher viscosity for the air cooled engine heat.
But after putting about 3 or 4 hours operation on it, I checked the oil level and found it was way down! I haven't yet refilled, so don't know how many ounces it has consumed. But it is consuming much more M1 0W-40 than it ever did M1 5W-30. I will refill it with 0W-40 and keep a closer eye on it.
Anyone have any theories on why this old style flathead air cooled engine drinks 0W-40? I've seen several people comment that their car engines consumed less M1 0W-40 than when they used M1 10W-30 or 5W-30.
Thank you.
Thank you.
