What is the diference in automotive and marine gear lubes? Can you use regular GL 4-5 Gear lubes?
Most manufacturers suggest that there is too much opportunity for air to get trapped in the casing if it is filled from the top. My OMC manual says to fill from the middle plug instead of the lower one.quote:
After draining, couldn't you fill from the top until it starts to come back out the check/fill hole?
You can purchase a pump from most stores that handle marine products, and also at Wal-Mart. Cost is about $7.50 and they last until you lose them. They are 99% plastic, but work with no problems. The pump has a hose on the top that screws into the drain hole. You leave the vent (top) hole open and pump it up until it comes out the top. Then insert the top plug, and remove the bottom hose and insert the plug there. Very little lost doing his.quote:
Originally posted by turnipgreen:
What do you use to pump the gear lube in from the bottom?
That someone that told you this, does there boat still run?quote:
Originally posted by Bror Jace:
Here's an odd-but-related question:
Someone told me that you aren't supposed to drain lower unit fluid out through the bottom but pump new fluid in through the bottom and flow the old stuff out through the top hole. Draining out through the bottom supposedly leaves behind water/moisture.
Any of you serious boaters ever heard of this? Is this some sort of lame April Fool's joke?
--- Bror Jace
I agree with this proceedure that Tony outlines. Buy the pump and go with the Pennzoil Sunthetic. I am currently running it in the lower unit in my 115 Johnson. For $5 a quart, you can't go wrong, Joequote:
After I complete the fluid exchange then one thing I do is clean both the drain and vent holes with a good cleaner such as brake cleaner or a strong detergent, then the next day or when it is dry, fill the cavity over the drain plug and the vent plug with GE clear silicon. When I am ready to change the lower unit oil again, I spray the silicon with any cleaner used to loosen bolts, and let it sit for 24 hours, then the silicon comes out and cleans off.
Just my way of doing it.
