Am running this mix right now in my 2003 Ranger FX4 Level II (4.0L SOHC V-6, automatic). First impression is that it quiets the engine noise a little...fuel economy seems to be about the same, engine pepiness is slightly less, but almost not noticable...could be just a little less noise...not that it was too noisy with the straight Mobil-1 5W-30 EP in there though.
Results:
Chuck
Results:
Blackstone Comments: When checked @ 210ºF, this oil was a mid-range SAE 30W, which is a little heavier than we typically find for a 5W/30. No moisture or insolubles found. No metals. The TBN was 12.3, quite high for a 5W/30. This oil is in serviceable condition and should serve your gas engine needs well.code:
Element VOA
Aluminum 0
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Molybdenum 92
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 257
Silicon 7
Sodium 4
Calcium 3184
Magnesium 16
Phosphorus 858
Zinc 999
Barium 0
SuS@210F 64.6 should be 56-63
Flash_F 425 should be >365
Fuel % - should be
Antifrz% - should be 0
Water % 0.0 should be 0.0
Insoles% 0.0 should be
TBN 12.3
Chuck
