Perhaps I should clarify those remarks....
One of the main selling points of this formulation is it's ability to prevent rust/corrosion of ferrous materials. I believe the 5 ppm of iron (which I've never seen from previous Amsoil formulations), may be a reaction between this fluid and some of the processing equipment that Amsoil uses.
The rest of the add pack looks pretty standard, ie a Calcium based detergent (like their diesel synthetics) and LOTS of good old ZDDP. No GF-4 oil, this...
The interesting thing is that this oil is intended for use in wet clutch motorcycles. Amsoil makes a point to stess it's NOT "friction modified". So that makes me wonder about the elemental form of the Moly compound??? In this case, they may be using it primarily as a corrosion inhibitor as well as a supplimental AW additive. This add could be sourced from Vanderbilt Corp, who seems to specialize in various moly compounds. Molecule would be the one to ask about that....
I'll be looking to see if the AMO/AME/AFL, xw-40 formulations follow suit and add the Moly....
Ted
