ALUMINUM 0 0
CHROMIUM 0 0
IRON 2 4
COPPER 0 0
LEAD 0 0
TIN 0 0
MOLYBDENUM 0 5
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 0
BORON 64 45
SILICON 4 5
SODIUM 0 2
CALCIUM 1722 3104
MAGNESIUM 598 229
PHOSPHORUS 822 905
ZINC 958 1033
BARIUM 0 0
first number is test oil value - second number is Universal Average
TBN 12.0
SUS
VISCOSITY
@ 210 ºF 63.9 56-64
Flashpoint F 430 >365
Water 0 0
Insolubles % 0 forst number is test oil value - second number is what the oil should be
Lab comments: No problems showed up in this sample of virgin Amsoil 0W/30 oil. The viscosity was in the middle of the 30W range. The iron is probably from steel holding tanks and transfer equipment. Calcium and magnesium and detergent/dispersant additives, while phosphorus and zinc are anti-wear additives. No moisture or insolubles were found. The TBN read 12.0, quite high. We consider a used oil TBN of 1.0 or less to be too low. This oil is in serviceable condition and should do well in your engine.
CHROMIUM 0 0
IRON 2 4
COPPER 0 0
LEAD 0 0
TIN 0 0
MOLYBDENUM 0 5
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 0
BORON 64 45
SILICON 4 5
SODIUM 0 2
CALCIUM 1722 3104
MAGNESIUM 598 229
PHOSPHORUS 822 905
ZINC 958 1033
BARIUM 0 0
TBN 12.0
SUS
VISCOSITY
@ 210 ºF 63.9 56-64
Water 0 0
