MaxLife Synthetic 5W30 API SL
nel
Northern CA
Data courtesy of Mark at Butler. Purchased this year during the AutoZone clearance. Note that this oil does have additives that would set off the test for anti-freeze.
code:
Valvoline MaxLife Synthetic 5W30 API SL, purchased this year
Cu 0 ppm
Fe 1
Cr 0
Ni 0
Ti 0
Ag 0
Pb 0
Sn 0
Al 5
Si 3
Na 1
K 0
Mo 255
B 0
Ba 0
Ca 3078
Mg 11
Mn 0
P 821
Zn 924
Anti-Freeze Trace
Fuel Dilution Negative
Water Negative
Visc cSt @ 100C = 11.8
Particle Count Data
>5u 2236
>10u 437
>15u 134
>20u 51
>25u 17
>50u 2
>75u 0
100u 0
Ferrous Debris (PQ) = 14
ISO Code = 18/14
Thanks. Now I know what's in the 20 qts I picked up at Autozone for $2 each. Looks like my 96 Blazer should be around for the next 2 years or so.
A nice load of moly and a healthy amount of calcium. With a 11.8 cSt viscosity, this is a sturdy oil that will hold up to some tough applications!
Thanks for posting this Maxlife syn VOA.
It's a beutifull oil, especially for clearnace prices. It will keep my wifes high reving MIVEC Outlander happy for the next year and a half or two.
Lottsa moly and calcium plus the viscosity is something I want in the higher revving engine in my garage. I can't wait to see some UOA's on this oil. I think we got a great deal with this AZ clearance. I believe this oil has a TBN of 10 as well so I am going to drift around 5k-7500 OCI's with it.
Mo at 255! Ca at 3k levels!
All for $2 bucks.
Compare this to the same priced but weak add packed $2 Havoline Syn at AZ..and its a no contest.
