M1 10W-30 Extended Protection
Oklahoma
It's FINALLY here!
Blackstone says the new M1 10W-30 contains:
code:
Iron 1
Tin 2
Moly 76
Potasium 1
Boron 232
Silicon 4
Sodium 5
Calcium 3281
Magnesium 13
Phosph. 791
Zinc 958
SUS Visc. 62.3
Flash 435
TBN 13.0
Have at it fellas! 5 quarts plus a Wix filter went into the Jeep over the weekend.
Well the future is now (Boron and Calcium emphasized).
But will Jiffy Lube change to a 'Every 5000' motto?
Not old SL oil after all.
The new Mobil 5000 and 7500 will be interesting also. Thanks for running this, they had a some at my local wal-mart today for $5.36 a quart.
-T
Thanks for the contribution millerl. I was hoping with all the hype about using the regular Mobil 1 for fuel economy that the viscocity would be a little higher. It looks about the same as the regular Mobil 1. That Boron sure is nice though.
Any first impressions?
True.
Very nice. Thanks millerl. I'm glad they made a 10w-40 also. Would be surprised if ZDDP is actually higher. BLK stone labs tends to report this number lower then other labs for some reason. I was told today that the percentage increases they are stating are compared to the GF-3 Mobil 1. Strong TBN.
[ February 02, 2005, 10:54 PM: Message edited by: buster ]
Viscosity is 11cSt@100C which pretty thick for a M1 30wt. The spec sheet indicates 10.1cSt@100C so could be lab error.
Looks EXACTLY (additive wise) like old SL except Boron. Could the TBN be coming from esters?
My uoa from 03/2004 showed 119 on Boron (10-30 SS SL). The new boron may be borate esters?
I think there are different quality additives that will show as boron.
Looks like boron has been increased by about 45% and Calcium about 37%. For $5 something a qt at Walmart, pretty tough to pass up on it IMO.
The majority of the tbn is coming from the calcium. It's the new Calcium carbonate/calcium hydroxide stuff from .....!
Esters have tbn's of about 1; i.e., they are pretty much neutral.
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=11;t=000255
Product date was 11/22/04 from buster.
GF-4 Mobil 1 5w30
code:
Molybdenum 55
Boron 150
Calcium 2500
Magnesium 7
Phosphorus 677
Zinc 749
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=11;t=000152
From October 23, 2003 VOA Mobil 1 5w-30
code:
Molybdenum 78
Boron 198
Calcium 2971
Magnesium 12
Phosphorus 849
Zinc 955
This Mobil EP 1 10w-30
code:
Moly 76
Boron 232
Calcium 3281
Magnesium 13
Phosphorus 791
Zinc 958
So what are we seeing here. Did they change add packs on both and adjusted the levels accordingly?
[ February 03, 2005, 10:21 PM: Message edited by: 427Z06 ]
Hard to say. These Lab Variations make it hard to tell. I'm thinking it's a % increase of somewhere in the middle of the GF-3 or GF-4. Nice balance of additives though regardless.
It sure would be nice if the EP oils were roughly the same price as the old SL/GF-3 M1, and the SM/GF-4 oil was in the $3.50 range. If the new oil is much more it might be a good idea to stock up on the SL version. The SM/GF-4 doesn't look like $5 a quart oil to me...
