FYI:
HIGH TEMPERATURE / HIGH SHEAR RATE VISCOSITY
There are four test methods I found for measurement of this property. Each method evaluates engine oil viscosity by subjecting it to conditions of high shear rate (1x10^6/s) and high temperature (150 degrees C).
ASTM D4683 and CEC L-36-A-97 utilizes a motor driven tapered rotor that is closely
fitted in a matched stator. The rotor exhibits a reactive torque response when it
encounters a viscous resistance from an oil filling the gap between the rotor and stator.
The unit is calibrated with reference oils.
ASTM D4624 utilizes a capillary viscometer which responds to the apparent shear rate
at the walls of the capillary as determined by the pressure drop and flow rate through
the capillary under desired conditions. This unit is also calibrated using reference oil.
There's also CEC L-36-A-90 (ASTM D4741) and D5481.
I've read API uses ASTM D4683, CEC L-36-A-90 (ASTM D4741) or D5481 for J300 classifications.
Update. Found these on the ASTM website:
D4683-04 Standard Test Method for Measuring Viscosity at High Shear Rate and High Temperature by Tapered Bearing Simulator
D4741-00 Standard Test Method for Measuring Viscosity at High Temperature and High Shear Rate by Tapered-Plug Viscometer
D5481-04 Standard Test Method for Measuring Apparent Viscosity at High-Temperature and High-Shear Rate by Multicell Capillary Viscometer
WITHDRAWN STANDARD: D4624-93 (1998) Standard Test Method for Measuring Apparent Viscosity by Capillary Viscometer at High Temperature and High-Shear Rates (Withdrawn 2004)
[ December 29, 2004, 12:50 AM: Message edited by: 427Z06 ]
