The old myth about "parafin" in oils has been hashed out here on various threads. Paraffin does NOT have any connection to paraffinic oils whatsover.
See:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=4;t=000343 where we stated:
quote:
Mineral Paraffininc Base Oil - 64742-54-7; VI of +94 to 120, any group.
Mineral Naphthenic Base Oil - 64741-96-4; VI of -15, any group.
Mineral Aromatic Base Oil - 64742-03-7; VI of -185, any group.
Hydrotreated paraffininc, heavy - 64742-52-5
Hydrotreated paraffinic, light - 64742-53-6
The designation of Paraffinic, Naphthenic, or Aromatic simply describes the structure of the oil molecule. It has nothing to do with waxes, solvents, or being smelly. All mineral oils contain waxes which require Pour Point Depressants to keep the waxes in oil from crystalling at low temps.
See:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=21;t=000024
and
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=21;t=000032
The older oils were a mix of paraffinic oils and naphthenic oils. It was the poor quality VII's that broke down and sludged, and for about an 18 month period, there was a lot of sludge cases.
Paraffininc oils don't solve the additives very well so a small amount of naphthenic base oil is added for solubility reasons. Back then Group I parafinic oils were the most oxidation and thermally stable oils available, whether from Kansas, Oklahoma, Texas or Penn. crude.
So it wasn't the base oils, it was the VII that caused sludging. And this was also before we had secondary anti-oxidants, and good dispersant/detergents. Texaco, Shell, and Standard also had this problem as well, it just wasn't advertised as much.
Today's VII's are much more stable and we learned much about what works and what doesn't.
[ October 22, 2004, 11:42 PM: Message edited by: MolaKule ]
