Y'all need neighbors like this one.
by simple_gifts
1 minute 55 seconds ago
F-106 Fumoto Valve
by DBMaster
46 minutes 21 seconds ago
Propane/Oxygen vs Oxygen/acetylene
by Vern_in_IL
56 minutes 10 seconds ago
CarQuest Red 85372 Cut open
by blupupher
58 minutes 58 seconds ago
Battery dead on new car
by Leo99
Today at 05:22 PM
1997 Saturn P0326 No power
by nwjones18
Today at 04:29 PM
Can I use lower weight ?
by ST2008
Today at 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
Today at 03:32 PM
Holdup
by Whitewolf
Today at 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
Today at 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
Today at 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
Today at 02:52 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
80 registered (AnthemBassMan, 4WD, Bandito440, AlaskaMike, Astro_Guy, asiancivicmaniac, 10 invisible), 1629 Guests and 6 Spiders online.
58952 Members
66 Forums
253739 Topics
Page 1 of 2 1 2 >
#474700 - 01/30/03 09:29 AM Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
mikeyoilnutt Offline
Loc: San Bruno, CA
Test was done by Blackstone Laboratories
Aluminum 2ppm
Chromium 0ppm
Iron 2ppm
Copper 0ppm
Lead 0ppm
Tin 0ppm
Molybdenum 1ppm
Nickel 0ppm
Manganese 0ppm
Silver 0ppm
Titanium 0ppm
Potassium 0ppm
Boron 357ppm
Silicon 7ppm
Sodium 1ppm
Calcium 2542ppm
Magnesium 267ppm
Phosphorus 1019ppm
Zinc 1166ppm
Barium 0ppm
SUS [email protected] 78.2
Flashpoint 435F
Insolubles 0.0
TBN 14.0
#474701 - 04/03/03 04:17 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Chris A Offline
Loc: DFW, TX
Anybody know the sulfated ash of this oil?
#474702 - 04/04/03 12:06 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
MolaKule Offline
Loc: Iowegia - USA
No, but an educated guess is that it is about 0.8%.
#474703 - 04/04/03 02:02 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Chris A Offline
Loc: DFW, TX
Interesting, I had read on the net that it was .9%
Is this an educated guess based on additives? If so, I'm impressed.
#474704 - 04/04/03 04:31 PM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
FowVay Offline
Loc: Southeastern USA
What is the role of the boron? It seems to have a sizeable dose but very little moly.
I wonder how this would compare against the Pennzoil Longlife 15W-40?
#474705 - 04/04/03 10:40 PM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
MolaKule Offline
Loc: Iowegia - USA
Boron is a multifunctional additive but is primarily used as an Anti-Wear (AW) additive.
It also functions as:
1. A detergent,
2. A Friction Modifier (FM)
3. anti-oxidant
4. anti-corrosive
additive.
#474706 - 04/07/03 09:48 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
FowVay Offline
Thanks Molakule, I am still trying to learn what the different additives do and what the best combinations are. Boron doesn't seem to be very common. I'm currently trying the Pennzoil Longlife 15W-40 in a old VW Rabbit. After a few oil changes I may try the Motorcraft also,,,, just to see if there's any observable difference.
#474707 - 04/09/03 09:30 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
MolaKule Offline
Loc: Iowegia - USA
Boron esters have only recently been brought out of the lab and into production.
#474708 - 04/09/03 12:37 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Bror Jace Offline
Loc: Saratoga, NY
The most recent versions of Chevron Supreme show both boron and moly. I believe Mobil 1 SS does as well.
I think motorcycle oils contains a lot of borates as they use this where moly is prohibited because of wet clutches.
As a matter of fact, this oil looks like it might be an excellent alternative to specialty (read: overpriced!) cycle oils ... but this is just a guess. [I dont know]
Quality control seems kinda cruddy, though. look at the aluminum, iron and other contamination. [Freak]
--- Bror Jace
#474709 - 05/16/04 03:02 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Bio-T Offline
Loc: London, AR
Blackstone Labs, 5-10-04 Update, Motorcraft 15W40 CI-4
Iron-1
Boron-321
Silicon-5
Sodium-1
Calcium-2909
Magnesium-258
Phos-1138
Zinc-1388
[email protected]
Flashpoint-420F
No TBN
#474710 - 05/16/04 03:25 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Motorbike Offline
Loc: The Tropics of Antartica
Sulphated Ash .09
#474711 - 06/13/04 09:23 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Last_Z Offline
Loc: San Antonio, TX
That oil looks killer! What's the limit of sulphated ash before the plugs get jacked up in a gas engine?
I might try Penn 15W40 or this one!
#474712 - 06/13/04 08:08 PM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Steve S Offline
Loc: East of IGO
I have been using hdeo's ,the ash is not a problem.
#474713 - 06/18/04 07:05 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Last_Z Offline
quote:
Iron-1
Boron-321
Silicon-5
Sodium-1
Calcium-2909
Magnesium-258
Phos-1138
Zinc-1388
[email protected]
Flashpoint-420F
No TBN
Vette,
Did you forget the moly or you left it out because MC uses none?
I think this will be the next oil going into my LS1!
#474714 - 09/05/04 08:09 AM Re: Motorcraft 15W-40 Super Duty Diesel Motor Oil API CH-4/SJ
Last_Z Offline
Hey guys......where can I buy some of this oil? A Ford dealer?
Thanks
Page 1 of 2 1 2 >
