Mobil 1 0W40
Cordelia, CA
M1 SuperSyn 0W40 SL/CF
Analysis: Schaeffer's Lab 9/11/2002
code:
Iron 2
Al 1
pb 1
Mo 74
ph 1024
zinc 973
mag 20
cal 2744
silicon 0
Cst 14.66
Visc 40W
and for comparison.
code:
M1 SuperSyn 10w30 api SL/CF
Mo 88
ph 1020
zinc 1009
mag 20
cal 3343
silicon 1
Cst 9.81
Visc 30w
[ September 12, 2002, 10:16 AM: Message edited by: VaderSS ]
Thanks for the report Vader! No silicon. I wonder what they use as an anti-foam agent. Also, have they struck a good mixture here with a low amount of zinc and low amount of moly for AW? And Calcium is pretty high which is good for cleaning I guess
Ahhhh....the choices I must make. You guys are lucky that you have more than two engines to work with
Regards,
Oz
Statisically speaking, the ZDDP levels can be considered equal between the two.
You will also see an average of about 80 ppm of Moly.
