I'm looking to firm up the suspension on my old BMW GS and wanted to know how fork oil wt changes effects damping and if there is a way to predict or ballpark what I should use. Trial and error can be expensive.
For Example if I go from 10 wt to 15 wt what can I expect? Is there some kind of formula like going from 10wt to 15 wt will give my X% increase in rebound/compression or something like that?
On another note I looked at my owners manual and it lists several reccomended brands of fork oils. What I found interesting is that the wt was different between the brands. That makes sense, each company makes their 10wt a little different. So I guess when I make the change I should stick with one brand so I can tell if there was a true difference.
