I see this oil is very highly regarded for motorcycle use, and doesn't shear much at all.
I have used Havoline 10w-40 in my Honda 4Trax 300 4x4 in the past and it has caused slippage problems that quickly went away when I went back to Rotella.
It is winter and cold now so I need something that won't shear, and will last a good long time without interfering with the wet clutch. It gets used every single day, but generally isn't revved highly for long periods or anything.
Rotella 5w-40 is an option too but seems to shear worse.
Thanks!
Thanks!
