quote:
Applications
• Recommended for new and older diesel- and gasoline-powered vehicles, including personal vehicles and commercial vehicles such as on-road, off-the-road, truck rental, pickups, delivery, utility, and school bus fleets
• Meets or exceeds the diesel engine requirements of API CI-4 PLUS, Cummins CES 20078, Detroit Diesel, John Deere, Dodge, Ford, GM, International, Mack EO-N Premium Plus 03, Volvo and others; For gasoline engines, it exceeds API SL.
Features/Benefits
• Formulated for multipurpose use, simplifying inventory needs
• Outstanding wear protection and bearing corrosion control helps maximize engine life
• Helps speed cold starts even with low winter temperatures
• Enhanced oxidation stability and soot control, especially at higher temperatures, aids service life
• Improved fuel economy – when compared to conventional SAE 15W-40 oils
• Product is warranted against defect and has performance which meets or exceeds virtually all equipment manufacturer’s engine oil warranty requirements.
Approvals and Recommendations
• API CI-4 PLUS, CI-4, CH-4, CG-4, CF-4, CF
• API SL, SJ, SH
• Cummins CES 20078, 20076, 20071
• Detroit Diesel 7SE 270
• Mack EO-N Premium Plus ’03, EO-N, EO-M Plus
• Volvo VDS 2
