Dan, I think your way off base here in many of your comments.
Your also forgetting about Havoline containing 490ppm of Moly. ZERO corrosion. Your also forgetting about the fact that oils with strong dispersant additive packages contain many things in suspension while other oils will leave them behind. This fools the person who does a UOA.
Here is a quote from XOM
[ November 13, 2005, 10:20 AM: Message edited by: buster ]
Moly has nothing to do with attracting water. The issue with Redline being hydroscopic was from it's polyolester basestock. Remember something, Redline is not 100% POE. It does contain some PAO. Dave has told me it does.quote:
Moly--in large quantities--is garnering a rep for attracting H20 (yep, water). This is almost certainly the reason the Redline oils, most of which have about 600 ppm of Moly in them, tend to show high wear metal counts in most UOA's. (the wear metal may well be from corrosion).
Dan if dino oils were as good as synthetics, they would be using them in NASCAR/F1. They are a thing of the past for extreme applications. Whether cold or hot, synthetics are superior. 99% of us may not need them therefore they don't always show their superiority, but that doesn't mean the are not. Run 15,000 mile drains on a good synthetic vs a dino under tough condtions and perform tear down. I bet the synththetics will keep the engine much cleaner. I sure Roy Howell of Redline, former chemist at Lubrizol is quite aware of what works and doesn't work. To think we know otherwise is a bit scary.quote:
EliteEtc.com: We've had a few reports that the wear metals in oil analysis increase immediately after converting to Elite. Is this due to the same phenomonon?
ExxonMobil: That's right, Lisa. This is usually a sign that Elite is suspending some sludge containing wear metals left by your previous oil. This usually returns to normal after the sludge has been solublized by Elite and removed from the engine.
The process takes only 2-3 drain intervals after which your wear metals will return to a more normal level, or even a bit lower due to Elite's superior anti-wear additive package.
However, please ask your customers to fax a copy of their oil analysis report so that ExxonMobil Technical Support can review each situation individually.
