quote:
Originally posted by fuel tanker man:
Motorcycle oil is--for the most part--a HUGE RIP-OFF. . . . They'll tell you a bunch of tripe about "specially balanced additive packages" and such. . . . And they'll likely have a little more zinc and phosphorous than passenger car motor oils.
What Tanker Man said. Regarding the possibility of extra zinc or phosphorous, if it gets to the point where those elements would come into play, you're using too "light" an oil to start with. I know my Intruder 1400 specifies 10W-40, but I'd never run 10W-anything in a big air-cooled engine.
I used regular Havoline 20W50 dino oil. If I do say so myself, my wear metal results literally trounce the numbers being posted by folks who have used other oils in the HD big twin engine--including synthetics. So car oils can do a great job in motorcycles.
This goes back to your first statement. There's very little difference between car and motorcycle oils.
You really don't need a synthetic oil in your motorcycle--unless you plan on severely over-heating it. In that case, the syn may prevent oil from baking into sludge. But even then, the newer dino oils are extremely robust, and your engine would likely be toast long before any of the group II and II+ dinos baked into sludge.
If you're going to be running hot enough to warrant a higher flashpoint synthetic, you're probably just as well off or better off using SAE-50 aircraft oil. Single-weight (radial engine) aircraft oil is about as robust an oil as you can get. Unfortunately, it doesn't have a lot of corrosion additives, so it needs to be changed frequently if you do use it.
I'd use Shell dino Rotella, 15W40 and change it every 2500 miles. The Rotella is moly free, and will almost certainly have more zinc and phosphorous than the Motul made stuff Kawasaki is ripping you on.
Good choice. Since I live in a very mild climate area, and I never ride when the temperature's below 60F or above 85F, I've elected to use Pennzoil SAE-40 which I buy for less than $1.00 per quart on sale. The flashpoint for Havoline looks even better yet, I'm going to look for it and start running it. I don't worry about VI improving polymer breakdown. No polymers to break down. The viscosity I start with is the viscosity I end up with 5000 miles later at the next oil change.
On top of that, I've got more oil between moving parts and less non-lubricating polymers taking up space. Since I'm fairly gently with the engine most of the time, my oil's almost as clear when I change it as it was when I put it in 5000 miles earlier. Oil consumption in 5000 miles is less than 1/8" on the dipstick over that number of miles.
P.S. - I run SAE-30 in my Grand Prix. Not 5W-30 or 10W-30 (but, I have weather that allows me to do this, and I'm ALWAYS easy on the engine for the first five minutes of operation, just like my motorycyle). I run it for approximately 7000 miles between oil changes, and it's down less than 1/2 a quart over that distance and the car has 110,000+ miles on it.
Regards, Gary in Sandy Eggo
