A recent oil thread on a bike forum to which I am a member of has brought forth the claim that this is in fact true. My knowledge is limited on the actual composition of the oil, so I'm turning to this borad to see if additional clarification is available.
Are 0w40 and 5w40 synthetics more shear stable than 10w40 synthetic?
To quote directly,
Ethan
To quote directly,
Looking for more information,quote:
In conventional motor oils VII (little polymers) are used to create the multi-viscosity span. These are what break and cause the oil to go out of grade.
10w40 contains a lot of these (AMSOIL's new $9 10w40 may not) regardless of synthetic or conventional. The synthetics should contain less.
With 0w40 and 5w40 can be accomplished very easily by the blending of different PAO basestocks with different viscosity indexs. Take a slightly thinner PAO oil and mix it with this PAO oil and BAM! 5w40. It's even easier when the spread is different (I believe AMSOILs 10w30 and 0w30 have no VII).
So 0w40 and 5w40 (and 15w40) have less or no VII to break. The 10w40s will still have a few.
The old rule of take 40 minus 10 to get a 30 "spread" as a gauge for shear stableness went out the window when synthetics came into the picture.
So it's the way the base oils are blended in synthetics that give it more shear stability (and lack of polymer VII). The addition of ester VII also helps the factor.
Ethan
