We've had a Kawasaki Prairie 700 4x4 for about a year now - has 104 hours on it. After initial break in on Kawasaki brand 40wt oil, we have used M1 10w-30 with a Wix filter for the last several oil changes. I did some research on this site and now I'm not sure that this is the best choice. It runs well, but I am ruined by you folks always selecting the best
The spec calls for 10w-40 SF or SG or SH, SJ with JASO MA Class (whatever that is).
This atv has a belt drive/torque converter drivetrain, so there is no wet clutch and it is essentually an automatic transmission with H/L selector.
What do you suggest as an over the shelf choice at WallyWorld or local auto parts for my engine oil choice based on 20-30 hr OCI? I have been considering Delo 400 15w-40 due to our hot climate.
The front gear case oil specification is the same as the engine oil spec. Would you use the same brand/viscocity?
The rear gear case oil is for Mobilfluid 424, or Citgo Transguard Tractor Hydraulic Fluid. Since we also have a Kubota tractor, I already have Kubota UDT hydraulic fluid in stock, which I would like to use. I will try to compare specs, but again, any recommendation on the rear gear lube? The rear gear case contains the rear brake discs (wet braking), but the Kubota is like that as well, so I don't see why the UDT fluid would not work.
