Oil for the VRod?
ebc
Kingsport, TN
Greetings,
What oil seems to be the pick for the Harley VRod engines? They share oil with the clutch and gears like Japaneses bikes dont they?
Thanks,
ebc
I have had good luck with Amsoil V-twin 20-50. I first tried the Syn3 but it had extreme sheerdown. Do a search for my UOA on this site. Also check out some of the V-Rod Forums.
Since 20W50 is the recommended viscosity you might want to try Amsoil's 20W50 MCV bike oil, or Mobil 1's 20W50 V Twin. Redline also has some oil geared towards this type of use. In my aircooled HD's I have been happily using the Amsoil 20W50 in the motor and primary, and the their 75W90 in the trans.
I am not sure if this is ok to do but check out v-rodforums.com for info specific to this model. You will be amazed at how fanatical we are over there.
Ken
