YOu have nothing to lose by trying dino oil, except the price of the oil. Give it a shot, and give it a few hundred miles to get rid of any slippage if it doesn't immediately go away. Just avoid making it slip except to occasionally check progress.
CGLENN: You should have bought a harley, they never slip the clutch....engine dont make enough power to do that....quote:
Originally posted by cglenn:
I have a 1995 Honda Shadow 1100 which I just recently changed the oil with synthetic castrol "V-Twin" motorcycle oil. Now the clutch slips when put under a hard load. Ideas if any on how to correct ? I got home and drained the oil immediately while hot in hopes of getting a good drain. Is there any hope on changing back to a non-syn oil to hopefully correct ? My only thought is that maybe this oil is not meant for a shared transmission/wet clutch system but rather for Harley's with a seperate tranny. Thought as I really can't afford to take it to the shop for a new set of clutch plates.
hahaha."If Harley made planes, would you fly in one"?quote:
I think you may have other non oil related problems with your clutch. Check for proper freeplay in the lever.quote:
Yes- check the clutch setup. I highly recommend swapping out the stock clutch springs for K&G clutch factory springs (or Barnett). The stock clutch springs are fairly weak to begin with. I've been using Mobil 1 15w/50 in my '97 Honda since new and never had slippage problems.quote:
I have used synthetic in all of my bikes & I have never had a problem with clutch slippage.
