Hi y'all!
I'm looking forward to picking up a new-to-me 1999 KLR650 in a couple of weeks, and so I'm wondering if there are any significantly different lubrication needs for a single cylinder engine. Are big thumpers harder on engine oil than inline fours? Would certain additives be more beneficial than others? The KLR650 still uses a choke (really a fuel enrichener), so I know I'll have to be careful in its use so that I don't get a lot of extra fuel in the oil. Anything else to look out for?
In case you aren't psychic, the KLR650 is a single cylinder engine w/ 4 valves, 651cc, 9.5:1 compression ratio, water-cooled, four stroke, carburated dual sport motorcycle. It makes about 40 HP on a good day, revs to less than 8,000 RPM, and the specified oil pressure is only 14-23 PSI at 4,000 RPM, so its not a very stressed engine. In fact, the entire bike is pretty well known for its durability. The manufacturer calls for filter changes every 3,000 miles and oil changes every 6,000 miles, using 10W-40 to 20W-50. The engine is substantially unchanged in the 18 years this model has been made. I'll probably have it on roads of one sort or another for 99% of the time; I don't have any plans for serious off-roading with it.
Thanks!
Thanks!
