It looks as though Mobil1 has completely changed their line with Mobil 1 Extended Performance and Mobil 1 being synthetic, Mobil Clean 7500 being semi synthetic, and Mobil Clean 5000 being dino oil. This was taken out of the Mobil 1 website asking if the dino 5000 could be used in motorcycles
"Can I use Mobil Clean 5000 in my motorcycle or my boat engine?
If your four-cycle motorcycle or boat engine calls for an API SM, SL, SJ, SH or SG rated oil, you can use Mobil Clean 5000.
Obviously, if you have a two-cycle motorcycle or outboard engine, you must use a two-cycle oil. However, we recommend that you follow the recommended oil change interval in your owner's manual."
Someone asked if the Mobil 1 Extended Performance 15w50 could be used in motorcycles, It looks like this is the same thing as "red cap" even though they claim more Supersyn. I'd say more supersyn over their synth blend but I doubt it is any different than the previous 15w50 as it is still SL rated.
