How does main jet size effect overall lubrication of a 2 stroke engine (700cc snowmobile) when pre-mixing gas and oil vs. just using the injection system. Regardless of jetting the oil pump is opened by throttle position when using the factory injection system. If I gut that system and go pre-mix then the oil must pass through the main jet with the fuel and the amount of available oil would be determined by the main jet size. Am I correct or full of BS. Need the 2 stroke gurus. Thanks
