I own a 96 suzuki dr350 dual-sport motorcycle that i use to commute to work on, which is 4 miles round trip. I tried using a non motorcycle oil in it for the first time, mobil1 15w50, and shortly after switching to it, the clutch started to slip in a way that when you started off from a stop, the revs would build up but the bike would catch itself when you let the clutch all the way out. The bike has 6k on it and the clutch adjustment is fine, and the problem stopped when i switched back back to mobil1 10w40 mx4t.
