I've ordered a new cam, follower and rings for my Kawasaki quad.
I was thinking that I will want the oil to pump to the new camshaft as quick as possible. Can't prime it w/o it running.
Also I noticed that the Chevron 5w-20 has quite a bit of Moly which should help protect my new cam during break in and it should pump to the top end quickly?
I have some Torco assembly lube which claims to have Moly in it. I plan on putting it on the new cam and follower. I saw some of their Magnetic friction reducer yesterday
Might add a small amount to the oil too.
I'm not too worried about the wetclutch. I have had it slip when using oil with Moly in it but as soon as I changed the oil it was fine again.
I plan on running the oil long enough to get the T-stat to open, get it filled with coolant and maybe a 20-30 minute ride.
I'll drain it at this point.
Good, bad idea?
Good, bad idea?
