Recently on HTT a tech from a dealer posted the information below about Syn3 and a few trannies he's seen.
Can anyone comment on the Syn3 and it'a ability to withstand the gears needs in the transmission of the HD's?
Thanks
HarleyVROD, posted this on HTT.
Just passing it on.....but I have never thought it was a good idea to put engine oil in the tranny either.
" I finally got around to taking the 03 RG apart with a noise in the tranny.... grinding noise in all but high gear....... using SYN3 from first service on..... all 3 shift forks have burnt spots on them ...all ball bearings were toast ( very rough ) ..Main shaft is ok as is the main shaft needle bearing.......I will be replacing ALL bearings.. Forks...and sliding Gears ..... This guy does NOT Ride hard or miss shifts...
I have another Dyna 5 speed with shifting issues comming in next week... BTW its using SYN 3 as well..... this will be #3 ..Im not impressed "
Thanks
