veepster, I just finished intepreting a American Motorcycle Institute test of Auto-Rx/Cycle-RX on a HD machine using the "360" 20w-50. That oil ended up becoming a variable instead of a control in the testing because it was so different every time we tested it.
VR1 will work great but DO the analysis and get it 'read' by someone who knows what they are seeing.
If I had a HD engine if that type I would lean towards Redline 10w-40,Schaeffers 7000 Blend 15w-40 ,Amsoil 10w-40 MC oil, type chemistries.
I would use cycle-rx periodically and probably treat both the oil and fuel with LC and FP.
Terry
Terry
