I've got an '03 Harley Sportster 1200 that I've been running Amsoil V-Twin oil in and using Amsoil Superduty oil filters and I've had the common problem of oil blowing out of the air cleaner (small amounts, just enough to make a mess). I've been happy with the quality of Amsoil products thus far, but during a recent oil change I found myself lacking an Amsoil oil filter, so I put on the appropriate Harley filter instead with the Amsoil oil. To my surprise the oil stopped blowing out of the air cleaner immediately after switching to the Harley oil filter. Since the oil change I've run the bike at low speeds, high speeds (75-80 for @90 minutes at a time) and speeds in between, without the leakage that was occuring with the Amsoil filter.
I've racked my brain and the filter is the only thing that has changed since the last oil change; the air filter is the same one (original equipment).
I'm certain that the Amsoil filter is a quality product, but now I'm wondering if perhaps it is too restrictive for the Harley's relatively low oil pressure which is resulting in a pressure build-up in the case (causing the oil to blow out the head breathers). If this is the case, perhaps Amsoil should be made aware so they can design a filter that meets this need.
Has anyone else made this observation? Could an Amsoil rep comment on my observations? I'd be glad to give more information if needed.
Regards,
Rob
Regards,
Rob
