Not too sure where this belongs. If it need to go to another forum then someone take a guess and move it to the one it belongs in.
It's come time to change the oil on our 01 honda rancher ATV. The manual recomends a 10w40 oil. I was interested to try a lower cold viscostity since it gets a lot of starts in sub zero weather since it is primarily transportation to a hunting spot.
The manual also say to not use any oil that contains molybdenum. I assume this means any/all varations of molly. I believe this had to do with the transmission clutch pack. It has the electronic shift option.
What would you guys recomend for an oil? I was tempted to try Mobil 1 but it does contain a bit of molly from the VOA's I have seen.
